Suspension noises:
Ensure that the springs are seated correctly, then check your endlinks. Chance are they are improperly installed. I had a similar sounds and thats what it ended up being.
Did you change the top hat before you put the springs in? sounds to me like it clicks when you have the wheel turned....I would check to see if you've got play in the strut bearing assembly first...I had some stange sounds after I did my H&R and I changed both of the strut bearing assemblies and it went away...
After some jumping on the door jam (not fully jumping ;)) I was able to get the same sound. It really sounds like a strut or something related to the strut. I didn't change the top hat before the springs went in, I should see about getting the top hat removed and checking out the strut bearings...
Thanks for the assistance everyone!
