Subwoofer Noob AGAIN
Protege5
Just purchased a small 10" Clarion w/120amp.
Hooked the aux wires up, making sure L & R match, connected the power wire to the positive on the battery, then grounded the negative on the rear, wheel well.
But when i turn the key on accessories, deck fires up but Green light on the Amp does NOT turn on.
Maybe my ground isn't good enough, i know the positive is on solid.
Could the amp fuse be needing replaced?
sooo confused?
As well, there seems to be a third small wire along with the Aux cables, assume its the Remote. But its by itself.
Tightened all the connections, still no light on the amp.
Blue wire has to be hooked up as it turns amp on and off. Do you have a fuse in the power wire? If not it probly blew the fuse on the amp
Just ensure your Ground is solid, your remote wire comes from your deck (this tells the amp to power up), and your power is good - should come right on.
