Stock Boost Pressure ?????
15.6psi. it is on the mazda website. well was when the car was still up there. but you can dig around. i'm sure if you googled it you would find it too.
Is there a GOOD way to get boost to hold without doing a piggyback? Will a manual boost adjuster help to hold the boost at say 16psi all the way up?
If it will do you really need the MAP clamp also or if I set it at the 15.5 will that not be needed?
Thanks,
I did I just installed the Forge valve with the blue spring. I get some surge to 17-18psi then tapers off to about 12. Just want to climb to 16 and hold.
Will a MBC give you the PTFB (part throttle full boost) issued that happens with a WRX??
