Stock alarm system question
NDM-SPEC
Mazdaspeed 3
OK I was taking a look under my dash and I saw the harness connector for the little red alarm indicator light was not plugged in anywhere. Where does it get plugged in at. I'm not even sure if my car has the alarm system anymore...Kind of a newbish question but what would be the best way to check that??
if you look under the dash to the left. if you are facing forward. but if you are on ur back it will be on your right. its a black box that should say mazda on it. it might even say mazda security. but that thing ur talking about is ur shock sensor. and it can ony plug in to one spot on the alarm box. just look around. let me know if you need anything else
edit. sorry i read wrong, ur talking about the red light thats in the cluster surround right? it should still only have one spot to plug into on the alarm box
