So, my car has been hesitating for quite some time. I recently got a Unichip installed and "tuned", but who knows how well. My MSP hesitates under WOT and the boost fluctuates from 5-10psi and it is supposed to be set at stock on Map A and 8psi on Map B. These settings don't matter as it does what it wants, when it wants. I believe the solution to this problem would be a new wastegate - would this cure the hesitation problem also?
To define the hesitation I am experiencing, it is like the car won't hold boost. For example, my boost gauge will read 8psi but my car will feel as if it is lagging and it will do this under WOT through the rpm range. I checked for leaks with soapy water and didn't find any. I have a minor misfire. I say minor because you can only hear it missing when you listen to the exhaust and you cannot notice it when driving (no stuttering from the misfire). Any ideas?
