STI "Pink" injectors
atticus1398
Contributor
07 CX-7 GT, 01 CBR929RR
Anyone know if the STI pink injectors are a direct swap for the WRX Blue 440s?
Thanks,
Shane
I'd like to know this too. My friend has an Sti and when he upgrades I would like to know if I can use them in my MSP?
USDM:
JDM:
correct?
Cool, the cheapest Ive found them are from one of the HUNDREDS of vendors on the Subaru boards. $260ish. You should hear those guys b**** about two week wait times for parts delivery. Hilarious
Look into getting injectors from the 06 wrx, they flow slightly more than the sti pinks 550 cc vs 560cc and can most likely be found for cheaper check out nasioc.com
also isn't the pinks low impedence injectors? or did I dream that, I am almost sure people posted that here
They are high impedence.
yeah for sure there, I just ordered a set of RC 750cc highs, that will go nicely with my AEM :D
with the AEM it will idle perfectly... or at least thats what I am told, I will find out for myself in a couple of weeks
will idle fine...just a bit longer cold/hot starts.... cold starts worst.
damn im looking for injectors too...
Did you guys knew that both blue and pink injectors are the same, the only thing that changes is the end caps which will restrict the injection.
