who did your custom kicks?
do you the contact info on who did your kicks and what did they charge yout?
They look great! could you email me the info tdamore@adelpia.net
thanks
thanks
(rockon) (rockon)Rider69 said:Not sure of all the specs on my system and too lazy to look it all up.
Current Head Unit: Pioneer DEH-P9300
2001 top model, lacks MP3 support.
50x4 Amp
3 4V outputs
Various Timing and EQ settings
A good overall unit, but since it lacks the MP3 support and the screen is starting to have some defects, this unit will be replaced soon.
Front Stage: Focal 165K3 Components
6.5" in Door/Mid-Tweet in Custom Kicks
Excellent imaging and sound. Tweeters are a bit bright, but they are titanium. Next set will have some silk domes. Could benefit from some additional Mid-bass from the 6.5"s.
Rear Speakers: Focal 165HC Coaxial in Doors
6.5" Coaxial Speaker.
Sound Quality is good from these coaxials, with decent bass response, highs and mids also sounded good.
Found that these drew too much attention away from the front stage, so they are now faded out of the system. New system will not have rear speakers.
Front Amp: JBL p80.4
40x4 amp bridged to 160x2 to run the Front Speakers
Amp has performed remarkebly well. It is obvious that the power outputs are lower than rated, but not much. Amp has delived clean sound and am quite pleased with it so far.
Rear Amp: JBL p180.2
Looks the same as other amps. 90x2 to drive the rear speakers which as I have mentioned are faded out of the system
Subwoofer: Elemental Designs E12K.44
This sub is mounted in custom built (by MaxxBling) enclosure to the right side of the hatch.
This sub is extremely versatile in that it does not require much airspace and hits really low and loud. I have recommended this woofer to many people and have not heard anything negative about them or the company (except for Asylum's mishap). With the power I am giving it, I expect that I need a better, more capable enclosure though. Next system will probably go with 2 10's or another 12 for an extremely booming setup.
Sub Amp: JBL pB600.1
looks the same as the other amps.
600x1 @ 2ohms
Amp has been really good. It probably has an output short of the 600W which is fine because it is more that the woofer's RMS capability anyway. Haven't had any heat issues or any other problems to think of with these amps.
Wires/Cables/etc: All Power & Ground Wires from Knukonceptz.com along with Fuse Holder. RCAs, Distribution Block and Cap from Streetwires.
All in all, happy with everything so far, but that is never good enough, is it? That is why I am planning out a system with new HU, 2 7" or 8" Midbasses in each door, 5.25" component system in kicks and more, cleaner power to each. 2 10' or 2 12" woofers and more power to them. Everything in custom fiberglass housing and more.
Here is a pics of the current hatch setup:
