In the past month it has taken longer than normal but nothing like today where I held the key and after 2-3 seconds it did not start. Round two it fired right up. It did the same thing when I left work. I live in Southern California so it was 70 or so this morning and 85 or so in the afternoon. I tested the battery off and it registered 12.85 volts. With the engine running my multimeter registered 13.54 volts. So it looks like the battery, the alternator, and the voltage regulator are all doing their jobs. So is my starter going out or starter solinoid? I am guessing this as the last 5 times I have tried to start it, it will not start after a couple seconds and then on the second attempt it fires right up. Or am I way off base here?
