stained CAI??
bazooka joe
No words
Moderator
Contributor
92 & 16 Meyatas
maybe you can help...my injen cai is spotted and i can't seem to remove the stains??? i've tried numerous products...any thoughts? thanks all!
MotegiMazdA said:
did you try some mothers aluminum or chrome polish?
no, i tried eagle one "never dull" and that just shinned it up but didn't remove the stains.....maybe i'll give it a try?
bazooka joe said:
didn't think of that what grit paper you think?
1500 then 2000...if the 1500 is taking too long u might get away with 1000 then the 1500, 2000...then some polish.
Dexter said:
id personally go down to 600 , but thats probably just me
yeah, that's true, you can probably go down to 600 on metal. I was just thinkin about paint...you dont wanna go that low.
is the intake SS? I thought it was aluminum..not sure though since i dont have one (shrug)
I have found flitz to work on just about anything though, which is why I reccomended it.
couldnt u just use some rubbing compound...that s*** should come right off.. no sanding..
If you want to go with flitz, I think I picked it up at Ace hardware here in town. But a rubbing compound should do the trick as well. I would try it on a small area first to make sure it doesn't scratch.
http://www.flitz.com/
tonkabui said:
yeah, i was just going to suggest some simple rubbing compound. should work.
ya that stuff is the greatist works on everything!!
