"SSAFC vacuum line connection" and "SSAFC to AEM Wideband wiring" questions
unless ur doin a low low boost app, hookin up the bottom line helps it blow off easier for less chane of compressor surge. but if ur boostin enough leave it alone
You can hook up as many lines to the vacuum line as you please, I have 5 running to mine.
And only run a line to the top nipple on the Type S, the bottom one that's pointed diagonally should be left as is. That's how I have mine setup, search the DSM forums if you want more detail about it.. those guys use the Type S a lot.
awesome info. Sooo I took the top nipple and connected it to the vacuum block... In my head that seems correct.....
How wrong am i?
