Squeaky Windshield?
ryannn
2008.5 Mazdaspeed 3
Didnt know where else to put this, but does anyone else have an issue with the windshield squeak or creak when you go over the smallest of bumps...
I've had it in at the dealer and they said they cant do anything about it. Said there are tabs or something and they squeak all the time. Anything a guy can do?
My windshield actually does this when cold.
I don't know what it is.
I've had the squeaky windshield for a while, now....
even my windows squeak. As soon as I get some free time, I'm gonna take it to the dealership.
Just letting you know you aren't the only one ;D
Kain was being sarcastic. This may actually be the most common, and posted about, issue with the MS3. A search would yield days of reading material.
C'mon Kaaaiiin ... LOL . Dude no worries this happens to everyone. It's his way of saying search around you'll find lots of threads.
Nope, you're the first.
Kain, I always like your sense of humor on here but I have to chime in for Ryannn's sake. There is definitely a recall for the squeaking windshield, they replace the clips that hold the plastic piece behind the wipers. I had it done last winter and it fixed the problem, I assume the recall is still valid, it sounds like your dealership is giving you the run around. I'm pretty positive you could search on here and find the service bulletin about the recall or try going to another dealership.
I had a similar problem with a creaky dash/windshield and the dealer installed something they called a dash kit. They said it was shims and foam strips. They said it was a common problem with 07 MS3s and there was a TSB. Even though mine was a 08 and didn't fall under that TSB they did it anyway. It hasn't made a sound since.
The TSB for the windshield cowl fix is a crapshoot. Some report initially that it cured the problem only later to say that the sound comes back. I had my dealer do the TSB and they doubled up on the pads they put in, and it's been four months and no squeak or rattles to report. There is also a detailed fix for it that's not too difficult if you don't have success with the dealer...or just don't want the inconvenience of going in to have it fixed.
Here's the thread in the other sub-forum. And here's the long post I made in that thread with the TSB info in it:
Got back from the dealer a few hours ago. Just to recap a little:
The Service Manager (SM) ordered the 8 foam clips a few weeks ago and I finally had time to bring it in this morning. I had talked to her on the phone about the TSB and told her I was getting rattling noises from the area where the dash meets the windshield. She had no problems ordering the clips without verifying that I had the problem.
When I got there, she told me that even though the noise was barely noticeable and my VIN was out of the range covered under the TSB that she would still go ahead and have it done. She wanted to make sure she addressed my problem instead of saying, "Your car isn't covered under the TSB and we don't know what to do to fix it." She was VERY nice and went way out of her way to take care of my concerns. She later came out and told me that she found another TSB that she wanted to perform. See below (anyone know what I/P stands for in this TSB?):
LIGHT METALLIC RING/TAP NOISE FROM I/P ON ACCEL
Applicable Models
2004 - Mazda3 VIN Range: 000000 - ZZZZZZ;
2005 - Mazda3 VIN Range: 000000 - ZZZZZZ;
2006 - Mazda3 VIN Range: 000000 - ZZZZZZ;
Symptoms
800 EXCESSIVE OPERATION NOISE
820 UNUSUAL NOISE(EXCL. PINGING,SQUEAKING,OPERATION,RESONANCE)
MTOL - 4740 Dealer Repair Information
A light, metallic ring/tap noise may be heard coming from the I/P. The
concern is a one time event only, during a harsh clutch engagement
and/or while quickly letting off or stepping on the throttle.
The source of noise may be coming from the shift cable bracket. The
bracket is mounted on the body tunnel, above the exhaust system flexible
pipe. The heat insulation must be pushed back in order to access the
bracket.
Two studs secure the bracket. The bracket was designed to be pressed
onto one stud with a nut installed on the second stud. Install a nut on
the stud without a nut. (Locally source the nut, thread size 6mm x
1.0mm with a 10mm head.)
***Published in Sept/Oct 2005 M-tips***
1/19/06 - MTO updated to include 2006MY.
Since my car already had the foam tips, she added the extra set of tips onto the existing one since she already ordered it for me. She thought this would create a even better contact point. She said even though the above TSB I posted wasn't directly affecting my Speed3, she wanted to have it done just so we've addressed another potential cause. Now I don't know if I experienced the symptoms in the the above TSB, but I was glad they did it. I will find out in the next few days if both of these TSBs have helped in eliminating or at least reducing the chatter. Last thing: she also wanted me to keep her updated on if the noise comes back as they're getting a new insulation material that keeps cars from having rattles. If the noise comes back, I'll go in to have them add this stuff she says should help. I'll update this thread on what happens.
