Squeaking! Car sounds like a hay wagon!
my my...you guys have a lot to learn. lol
Energy suspension grease is not white lithium at all.
lithium grease is not tacky at all while the Formula 5 is really tacky. sticks nicely where as the lithium grease will wash away at the first sign of rain.
not trying to cause trouble, but if you dont believe me, then I invite you to buy one tube of each and compare. I know there will be a great differance in these 2. I have tried them both and the Formula 5 kicks ass over the lithium any day. :)
try it guys! Im sure you'll like it.
Formula 5 is NOT white lithium grease. That Formula 5 stuff is sticky as snot, and a lot more slippery. If you cannot find Formula 5, try a really good marine grease as it will be rated for use in wet environments.
one of the bolt holes is slotted. put that one in 2nd.
it shouldn't be closed up, are you sure you have the right size bushings?
yea im sure i have the right size,and it did not fully close but just enough to where getting the bolts to allign is a pain in the ass, but ill try wat u said thanks
Mine is squeaking so bad in the front and clunking in the back it's driving me nuts. Anybody got the part numbers for the bushings for the back and what can be done about the squeaky front? Sounds like the left rear strut is starting to squeak too. I can hear it when I get in and out of my car now.
