squeak fix?!?!?!!?!?!?
JCell
BEETEK!
2014 Genesis Coupe R-Spec
for anyone with a squeaking rear sway bar, stock or aftermarket, what grease do you use to fix it?
i've had my AWR rear sway (21.5mm) bar for about 1 year, and i have to constantly(weekly) remove the brusihngs and grease them with white lithium grease
anyone have a better idea?
My suspension is also squeaking horribly. But only when I come to a stop and accelerate again. I had someone look at it, and they told me it was coming from several places. Mainly the swaybar bushings and the endlinks. I purchased some AWR rear swaybar bushings to hopefully fix that problem, and I have a set of goldline springs waiting to be installed, and I plan on taking the endlinks off and lubing them real good when the springs go on. I got some "x-tra heavy duty" grease made by Lucus Oils, that is supposed to be superior to the lithium grease. I did alittle research and from what I read the lithium stuff isn't that good.
