Sport23's current dyno
Sport23
Contributor
2003.5 MSP
Horrible tune and conditions but I am happy with the numbers.
I need to:
1) Retune for my E85 mix. I knew my tune was off but this is dangerous! Thank you J&S for keeping my moto together!
2) Run on a much cooler day! It was hot outside and even worse on the dyno. 106.66!!
3) I need to get a 3" Cat back so I can install it and my downpipe
4) More boost!!
Mods: AEM CAI, Turbolife FMIC, TB coolant bypass, PG IM, Outlaw engineering thermal spacers, FP coil packs, 1 step colder extended reach NGKs, Steedspeed, Forge WGA set to 9psi, Boost Sciences RDV, Medieval Motor Mounts, SSAFC V2, J&S Safeguard
bro you s*** is running pretty dam lean if im reading it right.
pretty much your whole rpm range your above 12, that is really lean... especially on a stock block.
Unfortunately you are absolutely right. My AF is horrible, I think the only reason this engine is still alive is because of my J&S. I made a quick adjustment on the dyno after this run but I still need to the reset the ecu and retune the whole car for my E85/91 mix.
