Whats the first thing i should check? This video is under full boost/acceloration
It boosts up to 6 and drops down to 4?
Cracked manifold?
Cold Pipe cracking?
Wastegate actuater?
Boost leak somewhere else?
Ive replaced a lot of the vac lines... dont think its a vac problem. If it is, i think its the connection coming from the IC to the coldpipe. It is "loose" there... ive tightened the clamp as tight as possible and it still is a little wobbly ? I plan on replacing that to an aluminum pipe soon.
(vid just uploaded, may take a few to process on youtube)
<object width="425" height="350"> <param name="movie" value="http://www.youtube.com/v/YKW0YnK1iaI"> </param> <embed src="http://www.youtube.com/v/YKW0YnK1iaI" type="application/x-shockwave-flash" width="425" height="350"> </embed> </object>
Cracked manifold?
Cold Pipe cracking?
Wastegate actuater?
