or put abs sensors on the hubs if you are running an msp ecu
I preferred the cleaner approach of having the LSD ground properly to match the open differential to have the speedo gear fit. That's how I did it, and it has worked fine for 25,000kms, and I don't expect any issues in the future.Drop transmission, open it, take out gears & shafts needed to get to LSD, take out LSD, modify speedo gear so it will fit, reassemble transmission and put it back in.
http://www.imazda.com/forums/showthread.php?t=2701
The LSD obviously had to come out for this, and they charged me 50$ to do it; they had the machine to do it in house is my guess. Never saw pix as I dropped it off in the morning, went to work, and the tranny was all put back together at the end of the day.
All they have to do is machine around the area where the speedo would go. I saw pix online somewhere, and never found them again.
