SpeedCircuit Protege 2.5" Downpipe
Status
Not open for further replies.
HKPRO5
Supercharged Protege5
This is our heavy duty 2.5" stainless steel downpipe from our SpeedCircuit Turbo kit for the Mazda Protege.
*TIG-welded construction
*Heavy duty and built to last
*Stainless flanges unlike other downpipes that use mild steel flanges that will rust and break
*Dump tube for an external wastegate that routes back into the downpipe. Includes a flexible section in the tube.
*Includes flexible section towards rear of the pipe
*Includes two O2 bungs - one for your primary O2 sensor and one for an optional wideband sensor.
*Designed for optimal flow supporting 400hp
Shipped without a flange on the inlet of the wastegate dump tube, so it can be used with various different setups.
$225.99 Shipped (Lower 48)
PM me or Email me at HKSpeedCircuit@gmail.com
OK question is this flange for like a 5 bolt t3/t4 turbo? And also does it clear the ac compressor?
Actually it comes with a T3. So it comes with 5 bolt flange to fit that turbo.
Ill see if I can get more pictures.
It also clears the air compressor
It will come with the pipe so you can add a flange. ( the wastegate pipe cannot be removed)
really? hmm...i must be thinkin about the one kooldino was selling off his car then, which had a gt28 or something like that
The one off of my car still has the same Ford Style 5 bolt T3 flange, even though it comes with a T28 turbo.
Status
