How about the ride comfort?
do you feel any different?
in science overview, adding some spacer to the wheel will make the suspension softer. because of longer arm.
but do you really notice the different?
I'm considering add some spacer, for cosmetic purpose and softer ride.
I have installed 20mm spacers to front and 25mm to the rear and this set up is perfect for the OEM 19s
The wheels are just flush with the guards.
The V-project spacers weight in at 25mm 1.925kg for two front spacers and 2.106 for the two 25mm rears.
I used kitchen scale to weight these. Basically total weight of a little over 4kg.
The quality of the spacers are good and the studs are also good quality as well. I have gone through a lot of spacers with my Miata.
I will get some photos up as well when I get a chance.
