Source with better prices for 2014 Mazda3 Rear Caliper?
Passenger side rear is seized and I'm looking for a new one (Made in Japan). I've tried rebuilds in the past and they didn't last. Rock Auto has Dynamic Friction Zinc coated but I'm not familiar with this brand $85.
Mazda part is $290 should we just get this one to avoid future problems?
Is there an online dealer or source that has better prices? We get parts for our Hyundai from a dealer in Florida that are about 30% off, nice deal.
Thanks for help, Pete
You can try here ($201 with free shipping):
Alternatively, if you have a local auto junkyard/scrapyard/wrecker, you may be able to get a used replacement from there as long as you're willing to remove it yourself, or have someone remove it for you.
Thanks, so I'm doing the other side while waiting for the caliper and the piston will not retract all the way, needs about 1/8" more. Parking brake is down. I have the tool to screw the piston back in but it just turns without moving in.
Suggestions?
You're not supposed to twist the piston, they don't screw in. You just push it straight back. It's possible that by screwing/twisting the piston, it's been damaged. In my case, the same thing happened after I put the car into maintenance mode. I needed the piston retracted just a little bit more, so I used a brake pad spreader and a flathead to squeeze it a bit more. Worked just fine.
Are you sure that the 2014 Mazda 3 with cable parking brake is also like that?
I think it might take pressure AND turning, the tool I'm using only turns so I'll have to
apply the pressure.
I will give it a try.
apply the pressure.
My mistake. If your car doesn't have an electronic parking brake, the method I described does not apply. Sorry about that.
I used a clamp to press in the piston about 1/16" more then turned it and it did screw back in clockwise. All good now.
I bled these several times and the pedal still seems mushy.
I also recently got a CX-5 and when I test drove it first thing I said was these brakes are not
right they need to be bled so maybe this is normal for a Mazda.
Tried a couple of panic stops and the ABS engaged so, I guess it is okay.
