the general consensus is that after installing a turbo inlet, the change of your bpv will be completely different. a lot of people stated that they lost the majority of the bpv sound in its entirety.
I have the CP-E CAI and the RPMC turbo inlet with the stock plastic POS BOV, and you can most definitely hear the turbo spooling as well as the intake suction. I need to get a better BOV so it can circulate better.
go over, check youre couplers and make sure every things tight. a lot of times its compressor surge which is air releasing back into your turbo. common if youre turbo inlet wasn't installed properly. but, your bov/bpv will get quieter with the install of the turbo inlet, which will cause it to change a bit.
