smoked tail lights
Should fit. as far as I know, there is no difference in the taillight shape.
Soemthing is different in the 04-06 and the 06-08 tail lights because when you go to look at after market tail lights they only fit 04-06. I think the shape has changed slightly. To be on the safe side you should use uncut film since its easier to apply (you will have edges to hold onto when applying it) rather than being careful not to get your finger prints on the back side of a precut set. You would just need to trim the scrap off with an Xacto knife. Check these uncut sheets out http://www.decalfx.com/smoked_tail_light_film.html
