Olestra said:The install itself should reset the ECU. If it didn't, that means you didn't unplug the battery when you did the install.
CitizenPro said:Reseting the ECU after every engine modification would not hurt. It'll help the ECU learn the new shiet much faster. Unplug those cables, and tap on that brake mang......
