toucci said:I like my kartboy a lot. Can't go wrong either way, I guess price would be the biggest factor then. So kartboy wins. Muahahah
even if you do get the TWM you'll want the kartboy bushings, just keep that in mind.
Yeah, it was an easy choice...That's why I picked the Kartboy. Don't over tighten the bolt, and you wont damage it; problem solved. Use the time it would take you to install the heat sheild spacers, and bend the heat shield.YP5 Toronto said:Price is not everything....in the world of aftermarket parts..we should all remember that.
Twm shifter:
-6061-T6 billet aluminum
-unique inner bearing brace bushing which guards against bearing damage due to over-tightening
- kits include CNC machined billet aluminum heat sheild spacers (no bending or cutting of the heat shield)$40USD more.....easy choice IMO.
Pictures of the Kartboy:TXMazdaSpeeder said:Picture of TWM next to average sized spray paint can for size comparison
