shaking engine
Locker_09
when i rev up 3-4000 rpm my engine is shaking is this normal and when im going like 30 there is like a hovering sound and the sound speed up to when i speed up any body knows whats going on?
What year car and how many miles? Does it happen if you rev the engine with the car not moving? Are your tires in good condition?
Welcome to the forum.
Clifton
Automatic/standard?
Which model Mazda do you have?
Can you move your engine just by pushing on it?
Visually inspect your motor mounts. Look for tears.
Any Check Engine Lights on?
im confused as to what the symptom are.
In neutral/park, the car shudders at 3k rpms? Why are you revving that high in neutral/park?
Any other symptoms while driving?
no other symptoms while driving just when I rev it up while on park.Is it bad to rev up that high
There is no reason to be revving your engine while its in park. Its probably normal engine movement.
Hard to diagnose over the internet. I would have to see a video of the engine movement to say whether or not it is excessive.
