Setting up your AEM engine management
The original wire posting is not a good setup. I believe the bouncing tach is due to the diodes, one of these days I will swap in some high frequency diodes and see if that fixes it. I have never heard knock, you must remember that my compression is 8:1
good to see yours is running well. I hated the tach thing, and i remember when my fan was wired to the tach instead of the wire one pin over, that was a nightmare... I sometimes wish i had kept it and got it running right, but i just didn't have the time to do it. I'll be back with something new, bigger and badder than before :)
What would the spec of the high frequency diode need to be?
The crank will be sending a signal of up to 4200 hz at max rpm. I think regular diodes are tested at 60hz.
will the AEM delete the cam position sensor? anyway to get away with NOT using the cam position sensor with the AEM?
The CAM is needed to tell any computer where TDC of a particular cylinder is. Remember, the crank sensor only has 360 degrees, but each piston goes through 720 degrees in a cycle. If you take out the CAM sensor, the computer wouldn't know if it is at TDC of the compression stroke or exhaust stroke.
R4 is for the cam sensor, does nothing to help with the crank signal - try R2.
For the earlier (~99) 1.6 cars with the hall effect cam sensor set JPT2 to the 2-3 position. All pinouts are the same in other respects except these cars have no KS among other wires.
Use the FSM to determine the tach wire, refer to the AEM manual to configure one of your LSx outputs as a tach driver.
Frankly, you should use the AEM to turn the alternator on and skip all the diode sillyness... I'll leave that for you guys to figure out, but I assure you it's not difficult.
edit: I'm going to go back on my statement having the AEM control the *generator*. The difference between a generator and an alternator is a built-in regulator. The Protege already has a transistor to control the stator's fielding, but the ECU is supposed to control it. For a generic modern alternator (I just dissected a Honda one) the regulator controls the voltage even without the ECU, although the ECU typically has a provision for being able to fiddle the field windings. I'm not entirely certain right this moment if I should try to run an off-the-shelf regulator on top of the existing generator (and would this require I remove the field control transistor?) or build a circuit to control it. Regardless, both are mundane applications of theory and nothing more.
