Yes, once again I had it backwards. I had looked at the two diagrams of the camera and the radar, and was thinking that SBS was done by the camera. SCBS is linked to the camera. Anyway, my wife and I are both conservative drivers, and the SBS has been able to sleep with either of us at the wheel.As with my 2020, the 2017 uses the "radar sensor (front)" to operate the SBS according to that year's owners manual. It's safe to say you have that radar and the diagram in the 2017 manual shows it positioned behind the logo:
Regardless, knowing you have it and how it works is the main thing.
As for auto bright/dim of the headlights, I see in the sample sticker I linked in post #10 above that your model has "Fully Automatic Projector Beam Led Low/High beam...." That sounds like it. On my 2020 sticker they call it simply "High Beam Control".
To test for it, see if your light stalk has an "Auto" setting." Start the car in the dark (no garage door opener light on please), stay in park and turn the stalk to "Auto". The headlights will come on. Flip the stalk forward to the brights-on position. If the brights do not come, and you get a dash indicator, you've got that function. It only operates above a certain speed which is why you should test in park.
I would recommend using this function. I find it works quite well, very few false positive or negatives in engaging or disengaging the brights. The only downside I've encountered is when an oncoming car goes down into a dip the brights flip on and when he comes out of the dip they flip off. You kind of look like an idiot to that oncoming driver when that happens but when you get down to it, so what. It's very quick and you're not blinding him.
A final word on cameras and radar. While those bits of hardware may be present and operable with one function there is no guarantee the other functions that use them in other models are operable in another model. The cameras and radar are dumb. It's the microprocessors that interprets the camera images and radar signals to activate the mechanical controls. It's the chips and controllers for a particular function like SCBS or Lane Keeping Assist that may have been de-contented for the $500 savings in your model.
None of this safety stuff is in any way "autonomous" driving and if you set the various functions to low or medium sensitivity they are minimally intrusive for an attentive and at least moderately defensive driver. Elon Musk (and GM with their ads showing smiling people with hands off the wheel) should be taken out back to the woodshed for selling snake oil, my mixed metaphors notwithstanding.
My main concern, and maybe it's unfounded, is that one of our most common hazards is to come upon deer or elk, or have a deer suddenly bolt out of the ditch, on a snow packed or icy road. That situation takes some finesse with the braking. Modern ABS is quite good, and I realize the car is continually monitoring traction, nevertheless, I don’t want the car slamming on the brakes in those situations.
I had read a couple of reviews of the early SBS on the 2017 model that thought it was good tech that needed refinement. The complaint was the force that was applied to the brakes in what the driver considered to be a not so close call. That could be disastrous on an icy road with a steep drop off on the side.
I've only had the CX5 through one winter, but the Traction Control and AWD seem to work quite well. I'd still say that our Subaru Outbacks had slightly better AWD, but I like this car much better overall. Even this summer taking it up a steep two-track road with a lot of embedded rock, it did very well crawling over a couple of spots and keeping the power to the wheels that had traction. Sometimes you have to just give it a second to think about it and move the traction from a wheel that is barely touching the ground, but then it digs in and crawls right over.
Now if it would just use that radar to give me some parking distance information…
