Running without TPMS Sensors?
What happens if I run without TPMS sensors installed?
Will I have an annoying light flashing at me the whole time I'm driving?
I think I read somewhere that someone on one of these forums experienced difficulties when his dealership tried to do a TSB reflash on his ECU. Something like the computer couldn't complete the process because the sensors weren't there?
It's not like I need a sensor to tell me to check my tire pressure :-p
i dont have mine on since i switched to my new rims, and its not that bad, it doesnt flash it just stays there all the time. every once in a while, like once every 1000 miles probably, it will beep like 3 times, each time its done this it scares the s*** out of me its soooo loud!
Yes, it will stay on but not flash. The only problem I know of (and it happened to me) is that it can screw up a reflash. According to the service writer, I had to put my stock wheels back on for a TSB reflash after it failed without them.
Put all four TMPS sensors in balloon. Inflate to PSI where light goes out. Place balloon in glove box/center console/hatch/etc.
The car doesn't know if they're on the wheels or not.
lol great idea
spend the 220 and do it right the first time
IF you want to consider a useless item "Doing It right"
It's just another useless thing made for the "Masses"....Not a needed item on a car.
SO if you want to waste money...more power to you...but some of these guys could care less..and I would be right there with them.
I never run the stated pressure anyway..but I assume these would only be triggered on loss of pressure.....In which case..I am sure it woudl become quickly evident if you had atire go down.
Short answer is...Its called maintenance...Check you tire pressure once in a while.
And remember...this is just my opinion..as the statement you made was yours....we are both entitled and neither are wrong....they are just that...opinions.
I've got the $220. That's not the issue.
Some wheels, such as the 5 spoke Mazdaspeed wheels do not work with the factory TPMS sensors. Not sure if they accept another kind of sensor or not. I have yet to hear back from anyone on this.
I am a tire pressure nazi. Comes from years of SCCA competition and motorcycle racing. I'll obsess over a half pound!
I just don't want to have an annoying light staring me in the face while I'm driving.
The light flashes for a bit then stays on solid. I've been running without it all winter with my 17" and show tires and it's never been a problem.
Got new shoes today and funny thing is it never went off ? I thought maybe because the stockers were in the trunk but when I got home and dumped them and went to autozone ....No light ! I guess it never worked . Probably something else the dealer F*up and didn't mention to me . Unless they gotta be flat to send a signal. in which case maybe there is a checking timer of sorts and it will be on tomorrow when I wake up .
i agree they are usless for people who keep up on there car but its also not worth it to me to either look at a light on a brand new car or have to switch them between my summer and winter wheels sometimes ya just have to bite down and get what ya need unless ya dont care about lights
im not sure why certain wheels cant use them i have never run in to that what makes it not fit?
Some of you are failing to realize the reasoning for the TPMS. It has nothing to do with checking your tire pressure. Its a safety mech which of course will be standard on vehicles if not already.
For instance, I for one am thankfull for this safety mech. Considering I do alot driving, what happens if you run over a nail or a bolt or some kind of debris that has damaged one or more of your tires while on the road doing lets say...100...hehe Before you can feel it, this system will alert if psi has dropped 2 points. I would rather have peace of mind that I know I will know if there is something wrong before I can even feel it or be a cause of an accident or my own death.
I would not recommend operating any vehicle without this feature.
Good luck finding a balloon that will hold 30 psi! PVC pipe could work with a Schrader valve.
-enganear
I have a 2nd set of rims for my snow tires - I went all winter without the TPMS and I dont notice the sensor light at all. So don't sweat it and do without - save the $220 and invest it somewhere else in the car that you would notice.
yea i took my out in the process of switchin wheels and it didnt turn on for a day! then it got the point and turned on... now i got them back on! much better without that light!
any orange or red lights on the dash blow!
Yeah this morning the light finally went off . Took it about 15 hours to realize the sensors were nowhere to be found . Good luck with those saving your but in a pinch . (lick)
The balloon thing sounds cute, but I'm pretty sure the sensors only transmit while the car is in motion, to save battery life. So unless you set up your compression chamber with a mechanism to make it spin the sensors, it won't work.
Negative, vehicle does not have to be in motion. Sensors are activated once the brain of the TPMS is turned on once the battery is cranked. If you would like to run a test please do. Go outside turn the car on, release some pressure listen for those three beeps. They are sure loud enough.
