I have a 2011 CX-9 and wired a trailer kit to the driver's side tail light. The kit has 5 wires (Rt turn, Left turn, brake, lights, ground) that convert to the standard 4-pin trailer plug. I followed the instructions to a T and had all the right connections. Everything worked as it should.
However, halfway through my trip (a 24 hr. drive from Colorado to Oregon) the brake lights and running lights/side markers decided to stop working. Signals still worked. There was also a flicker in the rear left running light when applying the brake but no brake light. To me this indicated a short somewhere. Once arriving at destination I redid the connections to the driver's side plug. I originally stripped the wire needing to splice, wrapped the trailer wire around the exposed part, then electrical tape, for signal, brake, running light. I reconnected them using crimp connectors with dielectric grease inside of them.
Break lights work! Signals work! But ALL running light still do not work. These are the front orange side markers as well as all lights in the back (when the headlights are turned on). Headlights themselves work fine as do the turn signals (which are the same bulbs in front as the side markers). So bulbs are not the problem.
The BIG question: is there a fuse or relay for the running lights/side marker lights? I'm referring to all lights when you turn on the headlights, but not the headlights themselves. TIA
