Concept MSP
- 2003 Mazdaspeed Protege
The kit comes with 13 Cross Drilled & Slotted Vented 2 Piece Rotors, Cast Aluminum 4 Piston 2 Piece Calipers (Metallic Blue), Black Anodized Caliper Mounting Brackets, H2 Ceramic Competition Pads and Stainless Steel Brake Lines. Basically everything that you need except the fluid. The installation was not very difficult at all.
After buying this kit I got a case of the "might as well's", so I also added Centric rotors, Akebono Pro ACT pads, Russell lines & speed bleeders in the back. I also installed the Corksport stainless clutch line too. That way I had all new lines, and I could bleed the entire system all at the same time.
I just had the car out today briefly to bed in the brakes and they felt very responsive. I did about 8 or so 60-10 stops and didn't really notice any fading at all. I'll have to wait until Spring to really do some spirited driving, but overall I am pleased with the setup.
Some pictures:
Some pictures:
