Rico's build thread.
Got my cr3 rad brackets in will put those on today and my coil sleeves arrive today
Should be getting fs ze cams, intake mani, and pistons.
idk if ill be using pistons but cams and manifold i will and a head
i believe I do but the lights were cut off it for a custom project. the wires i beleive are still there tho. so plug and bulb are not there. idk if thats what you are looking for
Could you throw your spacers and MS3 wheels on the front so I can see how flush it is? Also, show how much thread is available on the studs. You can text me the pics
Got my coil sleeves for now
Installed my radiator brackets
Rack fully removed
Took left headliner off to get it done black
NOPE. takes a little time when you first look at it or hear from people that have done it before it sounds like alot. but its pretty basic stuff. unbolt bolts, take off like 4 of those clip on clip off clips and just unclip the side plastics a bit and take off pillars and it slides off.
gotta unbolt the roof light becaue there is a little clip covered by it FYI
