P purewhitemp5 Member : Pure White Protege 5 Sep 26, 2015 #1 Anybody know where i can get a inner wheel well pass. side rear. the jy around here are rotted out. if not i am going to go to local body shop to see if they can get one $$$.
J Jackie chan Member : Pro5 Oct 18, 2015 #3 Wasnt exactly hard to find. Just google it. There are some on ebay. And here's one for like $10. Theyre all over the place for cheap. http://www.partsgeek.com/catalog/2002/mazda/protege5/body_mechanical_-ar-_trim/inner_fender.html
H hornsfan10609 Certified Mazda Tech : 2003.5 Mazdaspeed Protege x2 Oct 18, 2015 #4 Beware the P5 splash guards are NOT the same as the sedan, the front screw holes won't line up. You need the P5/MSP/MP3 style.
P purewhitemp5 Member : Pure White Protege 5 Nov 21, 2015 #5 as post states i'm looking for the rear inner wheel well.......the actual sheet-metal inner wheel well that is welded to the quarter panel.
J Jackie chan Member : Pro5 Nov 22, 2015 #6 You'd probably have to cut it out of another protege. That's a structural part of the chassis. Pretty sure nobody makes them.
T The_big_dill Nov 23, 2015 #7 Inner wheel wells for the rear are not easily replaceable. If you are looking for the part, the only people who can provide it for you is Mazda.
M MarvinM02 Member : 2010 MazdaSpeed3 Nov 24, 2015 #8 do you mean this? http://www.ebay.com/itm/Die-Stamped...-for-Rust-Repair-on-Rear-Fender-/171723196538
M MarvinM02 Member : 2010 MazdaSpeed3 Nov 24, 2015 #9 ooops for the P5 meant this http://www.ebay.com/itm/Die-Stamped...-for-Rust-Repair-on-Rear-Fender-/111664621768
P purewhitemp5 Member : Pure White Protege 5 Jan 19, 2016 #10 already have that, i am looking for the inner wheel well that is on the opposite side of this panel.
