www.03msp.com
- 2004 Acura TL
One thing I clearly stated in my original post is that the bar should be wrapped up in bubble wrap or foam. Again, regarding fitment, I had no issues and I've done a lot of this stuff. Regarding modifying of brackets, the only bracket I would say needed modifying was to bend the emissions bracket a bit. Honestly, it would be nice if they gave a replacement bracket for that. Also, I ended up tossing the firewall bracket (that too would have been nice to have one for that). Simple "L" braces is all that is needed. I am happy with the way things turned out that I'm not going to even worry about making brackets - but CP should consider. Also, yes, a few more steps would be helpful for the "newbie".STAR 80 said:I too bought direct. Chris from CP, when he did leave a message he was very nice. But this isn't his first product.
This is what he states on ebay to sell the bar.
I quote:
BE CAREFULL! DO NOT WASTE YOUR HARD EARNED MONEY!
YOU GET WHAT YOU PAY FOR, DO NOT SETTLE FOR NON-FUNCTIONING PRODUCTS!
Triangulated strut tower brace for the MazdaSpeed/Protege 5/MP3/3rd Gen 1999-2003.5. Designed to replace the factory brace and strut attachment brackets. Constructed of lightweight high strength steel tube and is of solid construction, no joints to flex or pivot. Bar bolts to firewall for maximum rigidity and strength. Easily installed without major disassembly or down time with basic hand tools. DOES NOT require alteration of any engine or under hood components. Comes with detailed installation guide and all necessary hardware.
It mounts to firewall using nothing other than firewall sheet metal and your choice of washers. (As none were included) Something of which you do have to alter and does so with the removal and alterations of brackets. Which The last sentence clearly is incorrect. I altered my passebger side emission bracket and it came out rather nice-elly. But I can see where the majority of people will destroy the bracket due to the metal is weak and only a couple of bends will break the bracket.
And to be honest here only today did I actually find CP's website.
CPRACING.ca and that was by using his email address. Only then did I find the Acrobat installation file. That was a little more useful than not.
I like the bar. And presently its the coolest of the strut bar options. But the workmanship and packaging needs addressing. Any of you guys waiting for your bar Fear not!! You will be happy.
I will try maybe to make a quick install guide and show you how I modded the bracket for future installs. As it does intale a few step thaat are very neccessary and without guidance.
- Brian
