Retro taillights...anyone found these
The ugly ones that stick out and don't flow at all with the lines of the car.. You know, like every other APC product.
good example would be the tails on the green apc chauk board civic....it had greyish black retro tails :confused: (rice)
markspark is correct........................they have been delyed fo the p5, i never heard of them being made for the sedan
don't have time to search.
Who makes the best tails for the MSP? Not the JDM's and not the APC. I have been told that the APC's get moisture in them really easy. Thanks
If the moisture factor is the only reason you don't want to go with APC, don't worry about it. A bead of silicon around the sealing edges is 99% effective at keeping moisture out. Keep in mind that it'll be hard to find aftermarket units that *aren't* prone to leaking, for a decent price anyway.
Yeah, almost every aftermarket tail light assembly is prone to leaking. Some just leak sooner than others. The best thing is to seal the light yourself.
I've seen pictures of their tail lights filled to the top with water from rain. LAME.
