Request Switch Reprogramming on Speed 6
Daddy Pete
2006 Mazda Speed 6
I have a problem, the Request Switch on my drivers door is not working. I checked the one on passenger side and trunk and they both work. I called the Dealership, the guy in Service Dept told me to look in Owners Manual and it tells How to Reprogrma it. Well I have read over the section and it does not say anything about reprogramming.
I was wondering if anyone else has had the problem. If so can you tell me how to reprogram it. I hate to think how much I would be charged just to get this done. I did check to see the Batteries in Both Transmitters were good.
You can leave message here or email me at srvivr2795@yahoo.com.
Any help will be appreciated...
it is the button on drivers door and passenger door up push to open car door, etc. It is used with the Keyless entry system. The one on passenger door and on trunk work fine. The one on drivers door does not work.
Take into the dealer and have them fix it. It's covered under warranty.
Door lock switch?? There is no reprogramming of said switch... As someone else posted this should be covered under your 3yr/36000 mile warranty...
I had the same thing happen on my '06 Speed 6. It is the antenna for the request switch. Apparently with the wet weather they short out? Mine started working again all by itself. Take it to the dealer and get it fixed under warranty if it doesn't fix itself like mine did.
