Replacing upper molding above grill
It's clipped and riveted on. I took the entire bumper off to remove grill then separate the trim from the grill.
The service procedure for Mazda 3 is to drill the rivets out but I used pilers to break them. I watched this video for reference
https://youtu.be/5pkkAnsCuVY
I'll upload some pictures when I get a chance.
I have a pretty good dent of the upper molding above the grill. I want to replace it with this part: https://www.mazdaswag.com/oem-parts/mazda-upper-molding-tk48507e1d64
Looks like I just have to unscrew the old one to replace it. But, has anyone replaced this and is it fairly easy to do?
Did you replace the upper molding already? I just had the car for 2 days and i scratched the molding with the garage door. I need to replace it as well. How do you remove the metal clip/rivet on it? The plastic ones are easy. Thanks
Is it possible to replace the molding without removing the entire bumper? I have a nasty dent on it and I need to replace it.
I replaced mine without removing the entire bumper, just the rivet and nuts on the top. I drilled the permanent rivets. It can be tricky to remove the upper molding, kinda have to use force.
Similar Threads and Articles
