Red Loctite Removal
RelliMS3
Mazdaspeed3
So I was thinking about switching to my stock motor mount for a bit, but then i realized how difficult it is going to be to remove the mount since i put on red loctite. My problem was that I asked my friend what kind i should get since i had no idea and he said go with the red. I should have done more research. So now if i want to remove it, it looks like i need to use a lot of heat (about 350 degrees). If i apply this heat to the bolt to get it undone do i need to worry about compromising the integrity of the bolt?
PB Blaster. It's WD-40 on roids.
Oh i didnt even think of that because everything i saw so far said heat is the only way. Do you know if this will work for sure? It just seems like it will be difficult to get it past all the threads, especially since i'll be upside down under the car.
I know it works because I did it before.
Just get your happy ass under your speed and do it.
alright, thanks guys. I was going to use a friends torch but i'd rather try the pb blaster first.
Ingersoll Rand TiMax Impact Gun, i use one of these for work and i can take any bolt out of anything with little trouble.
