The other day when unlocking the car I noticed the left rear turn signal didn't flash, I figured it was just a dead bulb. When I rode in the car and used the left turn signal it would flash like crazy, like normal. Then for about a day it worked fine. Then the day after that it went to being out again and hasn't come back to working. I took the bulb out and it looked fine (other than the amber color paint flaking off), the filament is till intact, and there are no burn marks. I went to Advance Auto, had them look up the bulb # and I pulled it off the shelf. It ended up being the wrong one, and no one carries it. I've tried NAPA, Carquest, Advance, Auto Zone, even the dealership doesn't have it w/o having to special order it.
The problem I'm having it that the 2 prongs on the side that lock the bulb in and not directly across from each other, they are a bit offset. Every bulb I've got from the other places are directly across.
Any ideas?
Any ideas?
