Rear shock adjustment
06 LS MS6
07 BM GT (shell has been struck from the roll)
So I can;t remember whih one, BUt I had the distinct impression that someone infered that you can access the BC coilover adjustor from inside the hatch
?? true??
Which adjuster? You can access the damper adjustments by unclipping the plastic side panels and pulling them out some. Then just reach in there and make your changes. Or you can buy extensions and run them up and out the top.
Depending on the size of your arms, a lot of people can reach in through the jack compartment (left) and the light access hatch (right) to the top of the strut and adjust them easily that way.
