Rear Ebrake Line Help
HotPr5
hey guys..........I need help on removing the ebrake line from the bracket. I already took off the clip but I cant seem to remove them line because of the tension. I already have the ebrake disengaged. Any tips on how to remove this? Thanks
Brute force - use your thumb or other implement to push on the lever where it pivots at the caliper (in the same direction that it moves when the E-brake is applied)
This will give you enough slack to wiggle the cable out of the slot.
What I did was once I had the caliper unbolted the ebrake line just slipped right out. Best of luck you can IM me on AIM if you need any help JettaRacin41
