Rear Diff gear and Manual Transaxle oil choices
Klip
Contributor
2006 MS6 Sport
Just a few more quick questions here.
The owners manual lists six types of fluids:
1) Engine Oil
2) Manual transaxle oil, GL-4 (SAE 75w-90)
3) Transfer, GL-5 (SAE 80 or 90)
4) Rear Diff. oil, GL-5 (SAE 80w-90)
5) Power steering fluid, ATF M-III (e.g. Dexron II)
6) Brake Clutch fluid, SAE J1703, DOT3
I plan on using Redlines MT-90 for the Man. Transaxle oil. If I understand this correctly, the Transfer & Rear Diff lubricants use the same type of gear oil. In which case, I will be using Redlines 75w-90 Gear oil for both. Is that correct?
