Rear Diff Bolts are Sheared!?!? Need How To or Help!!! PLEASE!
So sorry everyone for kinda ditching out on this thread. So mazda ended up fixing the bolts under warranty. I had to b**** and complain to mazda but they finally did it. It still feels kinda loose so im wondering if he maybe only installed 1 bolt or something. But what ever, when im done with school in washington ill fix it myself at home. Anyways, so another problem they found while doing the bolts was the gasket/seal on my drive shaft (towards the front by the tranny) was torn. They said that it was probably caused by the shop that did my clutch replacement. NOT KNOWING MAZDA DID THE CLUTCH REPLACEMENT! So when i told them mazda did it, they s*** them selves. So I tried to get them to replace it and they wouldnt. Called the shop that did the clutch replacement and tried to get them to do it and they said no. Then called mazda and mazda said they have no say so in the situation and they cant make a dealership pay for anything. SOOOO after days and days of fighting with both dealerships and mazda themselves, it ended with a big middle finger to me! Im no mechanic but the mechanic at the 2nd dealer said the only way that seal or gasket tears is when it is taken apart and put back together if it catches on something. He said he has done it himself. And the gasket is attached in the drive shaft so you have to buy a new drive shaft which was $1200 or $1600..Something like that. So in conclussion mazda has lost my business along with my families business. Make your own decisions but hopefully you decide against mazda. Sry again for not leaving an update.
Yea Mine was and it covered under warranty.. The thing is the Mazdaspeed 6 has a transfer case issue.. Its covered under warranty just throw a %$%$%$ fit and they will fix it
Yep. Sheared mine off a couple months ago too. Lost the heads Snd the other half still in the diff itself. I tacked some other bolts to the ends still in the diff. And slowly wrenched them out. (after driving 40 miles down a local canyon in Utah) went to lowes home improvement store Snd bought some grade 8 bolts. Never had an issue since.
The stck bolts looked like ******* pop metal. Cheap and not strong at all.
