car isn't that new. It has 3800 miles on it. I don't baby it, but I don't drag race stoplight to stoplight either. I'm not afraid to punch it though. The clutch doesn't seem like a problem on this car. The wheel hop caused by a botched high rpm launch, super sticky track, low psi tires, and extremely weak factory mounts all culminated, I believe, in what I experienced. The clatter sound you heard on the outside wasn't audible from the inside. It sounded much more like hitting a washboard road at too fast a speed.
I believe as all this motion was happening, that the linkages to the shifter were out of alignment with the gear selector. Basically it was all bouncing around. Interestingly, you can grab the linkage (complete with counterweights) at the transmission side and SHIFT gears on the car. You can push it forward and back, and it will arc across a path. Also, you can lift up or push down on the weight and turn, and that selects other gears. With that part being counter-weighted, and with all the linkages being connected with soft bushings all over the place, AND with the motor mounts allowing all these parts to move back and forth a TON, I think therein is the recipe for shift control loss. It only makes sense once you witness the design at the transmission side. Just pull your airbox to see what I'm talking about. EEEK!
So, anyway, it all comes down to this:
Hopefully you fellow MS3 owners take something away from what I found out the hard way. Don't hard RPM launch the car like Mazda suggested to the magazine journalists. Don't race with traction control on (duh), and if you don't **** up the launch, nor loose the feeling of where the gears are within the shifter, the car will move nicely down the track.
And to the person(s) who've taken this post as a way to criticize what I've already admitted to being mistakes, ...you've missed the point of this post completely. You receive zero points for your effort. We are now all dumber for having to listen to your post. Good day.
<now where is the two middle fingers in the air smiley?>
To those who get what I'm saying here...sweet. Its all about learning experiences and what we can bring to the forum community. If someone doesn't have to go through the painful learning curve that I did, better for them, eh?
