rally armor mud flaps - install now or after winter tires
pcpower
rally armor mud flaps - install now or after winter tires?
Would it be fine either way? I'm concerned that if I put them on now to fit w/ my 18" wheels and then switch to a 16 or 17" winter tire, then it might not be fitted properly. I don't think my question even makes much sense but thought I should double-check. (enguard)
thx
You should be fine either way OR you can install them when you're putting on your winter wheels. Fitment shouldn't be an issue.
IMO, as bad as those things look and as ridiculously expensive as they are, I'd still go for fitting them with your summer tires. They may look a bit weird with winter tires, but who'll notice? Just my $0.02
I have a set of front RA flaps and I still havent installed. I can't bear the look of them...
Now for winter, I won't mind much.
How about flaps year round? :)
That angle is great, but if you were to show off the rear of the car..
I just do not like how big those flaps are in the rear.
