Agreed, I also needed to remove the passenger side tie-down hook.pdhaudio83 said:matt, i had to do some cutting of the underbody trim.
ALSO- word of advice. where the IC pipe from the TB goes thru to the underside (where the injen went thru) put a piece of hose around it so you wont scrape up your IC pipes if its close. i just did today. also look at the clearance with the brake res and the tb pipe.
