This is my first post on this site, so welcome me to your community. I have used the forum search and could not find anything that could answer my question.
I am trying to find out if the BP4W in the 98-2000 Miata and 04-05 Mazdaspeed Miata pistons are compatible with the standard BP-ZE found in most 323s, Protege's, Escorts and Miatas.
Do they have the same 20mm wrist pins? and also, if used in an older BP will it keep the same low compression ratio or is the deck height different on the newer blocks.
