Question on Strut Tower Bar
Ha! No doubt it's making evasive maneuver for a fighter jet!
I couldn't tell what type of the fighter jet is other than it isn't F-15 from the US. Then my son told me it's Russian SU-27!
that is correct
That is a great plane.
I have started having some creaking/popping sounds, coming from the factory brace, when I drive over rough surfaces. At least, that is what I suspect.
I know, that there is a TSB for this issue, but anybody encountered this issue before?
It seems like, it could be two issues causing this. One is, the bolts are not tightened enough and the other, some body parts are touching each other(not sure from the pictures which are those).
The bolted connections you're referring to are easily tightened after installation.
There is minimal movement following that.
