- 2001 Mazda MP3
Ok, as of now i'm running a 225 40 on my stock wheels at a 52 offset and i have 9/16" of clearance to the inside of the rear finder(approx 14 mm) from the outside of the tire
the wheel to the inside of the fender lip i have 3/4"(19mm)
The bent portion of the lip is .5" (12mm)
so TOTAL from the wheel to the outside edge of the fender i have 31 MM
The wheels i'm looking at 8.5 at +44 will put the wheel 27 MM closer to the fender, which is between the inside of the lip, and the outside of the fender.
So i need to roll, i know that. BUt i want to run a 235 tire, which is 10MM wider than my current set up, so half of that on one side plus the 27 MM closer to the fender my new wheels will be puts me at 32MM closer to the fender. 1mm larger than the space i've measured to have...
So my question, for those that have rolled you fenders, how much did you gain, or does it just bend the lip up?
And to be clear, i'm going to be running BC coilovers and i'm NOT going for a slammed look, just a nice level ride that's a little bit lower than stock
