Hmm, I am not sure about getting a new gasket. When I put a turbo on my MX-6 I just drilled the pan without taking it off and ran some oil through it to get all of the shavings, but a gasket can't cost too much so I say go for it.mofoaka said:thank you very much! i love this forum, great support! the shipping date says i'll be getting the kit by monday april 19th, i want to do the install myself, mechanical work is no problem for me, only thing holding me back is the FMU install, messing with ECU for the O2 signal modi. oh, should i go ahead and get a new gasket for the oilpan when i put the flange on for the oil receiver?
one thing i got to warn you about!!! on the oil return line running from the msp turbo to the oil pan make sure that it is recirulating properly. the msp block has a section that is taped for the oil return line right above the oil pan..... so if you tap the oil pan the oil will return at a lower point and could cause you to burn oil or overheat the turbo. i was going to tap the oil pan on my msp set up, but then after looking closer into things.... i decided not to. since i had the whole msp motor i removed the section taped for the oil return line from my other motor and used it. so in my case im set up just like any other msp out there...except for the bad vac & boost lines!mofoaka said:thank you very much! i love this forum, great support! the shipping date says i'll be getting the kit by monday april 19th, i want to do the install myself, mechanical work is no problem for me, only thing holding me back is the FMU install, messing with ECU for the O2 signal modi. oh, should i go ahead and get a new gasket for the oilpan when i put the flange on for the oil receiver?
1FASTMP5 said:one thing i got to warn you about!!! on the oil return line running from the msp turbo to the oil pan make sure that it is recirulating properly. the msp block has a section that is taped for the oil return line right above the oil pan..... so if you tap the oil pan the oil will return at a lower point and could cause you to burn oil or overheat the turbo. i was going to tap the oil pan on my msp set up, but then after looking closer into things.... i decided not to. since i had the whole msp motor i removed the section taped for the oil return line from my other motor and used it. so in my case im set up just like any other msp out there...except for the bad vac & boost lines!
(wiggle)
ill try to snap a pic for you tomorrow! kmofoaka said:ahh thanks, you got any pictures of it? so i can make sure to know where to tap it, to make things clear, when you said " removed the section taped for the oil return line from my other motor and used it. so in my case im set up just like any other msp out there.." does that mean you just used the old tap from the MSP block and put it on to ur stock block without drilling the oilpan? or did you have to?
That would be the best way to go. However, remember, many kits are made to tap into the oil pan so if you are unable to get the MSP tapped line, then don't worry too much about going into your oil pan.1FASTMP5 said:one thing i got to warn you about!!! on the oil return line running from the msp turbo to the oil pan make sure that it is recirulating properly. the msp block has a section that is taped for the oil return line right above the oil pan..... so if you tap the oil pan the oil will return at a lower point and could cause you to burn oil or overheat the turbo. i was going to tap the oil pan on my msp set up, but then after looking closer into things.... i decided not to. since i had the whole msp motor i removed the section taped for the oil return line from my other motor and used it. so in my case im set up just like any other msp out there...except for the bad vac & boost lines!
(wiggle)
This part you speak of is the MBSP (Main Bearing Support Plate) that has the oil return fitting on it. The FS engines have MBSP to strengthen the bottom end against crank walk. All the FS engines have it, it's just that the MSP's have the oil return line built into theirs.1FASTMP5 said:one thing i got to warn you about!!! on the oil return line running from the msp turbo to the oil pan make sure that it is recirulating properly. the msp block has a section that is taped for the oil return line right above the oil pan..... so if you tap the oil pan the oil will return at a lower point and could cause you to burn oil or overheat the turbo. i was going to tap the oil pan on my msp set up, but then after looking closer into things.... i decided not to. since i had the whole msp motor i removed the section taped for the oil return line from my other motor and used it. so in my case im set up just like any other msp out there...except for the bad vac & boost lines!
(wiggle)
LinuxRacr said:This part you speak of is the MBSP (Main Bearing Support Plate) that has the oil return fitting on it. The FS engines have MBSP to strengthen the bottom end against crank walk. All the FS engines have it, it's just that the MSP's have the oil return line built into theirs.
You're doing what now? Going back to turbo already?MP3skaterNC said:im doing the same thing to my mp3, however i have the msp ecu. so bam
The MBSP has nothing to do with the fuel system. What I'm saying is that the MBSP for the MSP has the OIL-Return fitting already built in, so you don't have to tap the oil pan at all. I hope this clears up any confusion.mofoaka said:so this MBSP, will i be able to tap into this? to return the fuel?
yes.....thats it! i didnt know what it's called. thank youLinuxRacr said:This part you speak of is the MBSP (Main Bearing Support Plate) that has the oil return fitting on it. The FS engines have MBSP to strengthen the bottom end against crank walk. All the FS engines have it, it's just that the MSP's have the oil return line built into theirs.
