zerosignal0
I ordered a set of coil overs today but I know Im going to have to adjust the camber. Im going 2 inch's down but will these work?
Ground Control eccentric bolt
When you lower a car, the alignment will change. These eccentric bolts will allow up to 1 degree (plus or minus) of camber correction to keep the handling sharp and prevent tire wear. Sold as a pair - one is needed per wheel
I found them on the flyin protege site.
Thanks
Thanks
