Protge321's Turbo Build
yes i plan on getting a tune, not right away but not long after. ill go with the -9psi spring then. thanks dub.
those bolt are either 11mm or 7/16th's... both fit...so...lol ... your choice? no, i think it's metric but not sure, get a couple of both, bolt are like 8 cents each, won't brake the bank right?
and i'm taking a pic of the e-clip right now, just give me a minute!
yeah the opening is about 4mm wide, but the whole thing is about 11mm wide
here's some random objects of comparison that were laying around on my desk...
wait...i hope that was an almond i just ate...
no, i don't know if you can...maybe, i just took it off for the picture, my turbo is sitting in the same room being worked on from time to time along with the rest of my car parts...lol
i don't know, i'd tried looking...
is it on the door panel where it also says your paint color code?
um im not sure ill check it out.
edit: not there, only the body color code. im sure ill find a tan thats close, just dont want the 3 gauge a-pillar to look tacky. (notcool)
i saw that.. i wish i could grab it but im buying that msp ecu, finished buying the coolant line stuff, and an oil pan and and gasket. if its still around next paycheck ill get it for sure.
i cant pass that msp ecu up, i have never seen one so cheap. (thumb)
im getting it for a 100.. just waiting for a reply with his paypal. im keeping my mp3 flashed ecu and header so if i go back to stock i still have what i need. so that would make it 250 for the reflashed one from spicyorangemsp.
Hell yeah, that msp ecu is hella cheap! For $100 you get a real msp ecu AND you get to keep yours.
